IC for low power current gain 3.3V 50ma
zcream
Joined Feb 21, 2009
20
I have a pulse that is approx 5ma at 3.3V
This needs to drive a device that needs 50-100ma at 3.3V
I can supply 3.3V or 5A for operational voltage.
any idea what IC I could use for this ?
I know I can build a current gain circuit from a npn transistor, but I am hoping that a low power current amp is available as a standalone IC.
zcream
Joined Feb 21, 2009
20
Just realized there are logic-level MOSFETs. Would you advise on the suitability of a BJT or MOSFET for driving 100ma approx. ?
I also realized that a MOSFET does not need a bias resistor at these low currents.
Only gotcha may be that I am using 3.3V not 5V
KMoffett
Joined Dec 19, 2007
2,918
Try an STP22NF03L from DIGIKEY...$1.10. It should meet your 3v logic switching and your load requirements. Down side may be that it's in a TO-220 case. Is that a problem?
Ken
zcream
Joined Feb 21, 2009
20
To-220 is actually good. I hate soldering SMDs. But it turned out my project had a problem with the clock frequency. So maybe I wont need this at all.
