IC for biasing opamp
Discussion in 'General Electronics Chat' started by akshay15, Jan 1, 2011.
  1. akshay15
    Dec 30, 2010
    9
    what are the IC's used for biasing opamps (both its negative terminal and positive terminal) i.e pin 4 and pin 7.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is not a bias. A single op amp needs electrical power to operate. Pin 4 is the input for the negative voltage, and pin 7 (pin 8 if a dual) is for the positive voltage input. These voltages actually power the internal circuitry.
    A bias is a voltage applied to one input pin - usually the non-inverting one - to give a permanent offset at the output.
    Back to the voltage supplies - the IC's supplying regulated voltages would be, then voltage regulators. They are usually complimentary to one another, so if you use a 7812 to supply a positive 12 VDC to pin 7, you would use a 7912 to supply -12 VDC to pin 4. Google "voltage regulator ics" to learn more about them.
  3. akshay15
    Dec 30, 2010
    9
    thanx ,,can you tell me what are the languages a microcontroller understands ?
  4. kubeek
    Sep 20, 2005
    4,686
    805
    Machine code specific for each microcontroller family, translated from different programming languages using compilers. If you really wanted, you could run Java on a PIC.
