IC-7473 or IC7476?
Discussion in 'Homework Help' started by pfelectronicstech, Oct 6, 2012.
  1. pfelectronicstech
    Jan 18, 2012
    178
    I'm doing another experiment in my program, and I'm supposed to wire a IC-7473 but I can't find that in my components. I could have just missed placed it, but I do have a IC-7476. Can that be used instead or its a completely different component with a complete different result from that? If i can't use that, I hopefully will find it or run out and buy one. Thanks for the help.
  2. ScottWang
    Aug 23, 2012
    4,933
    777
    Connecting Set(/SD) of 74LS76 to Hi, and then the others are the same.
    pfelectronicstech likes this.
  3. pfelectronicstech
    Jan 18, 2012
    178
    Wow, thanks for the help. I really hope I can find the right one before I start this experiment. It would make things easier. Thank you again for the help.
  4. pfelectronicstech
    Jan 18, 2012
    178
    Thanks guys I finally found it. My school sent me so many different IC chips and components its sometimes tough to find exactly what you are looking for. This part of the program is very, very interesting. Its just good to get your hands on all these components. It takes the theory you learned, and turns it into color. Thanks for the help again.
