ic 74164
Discussion in 'The Projects Forum' started by jayanthyk192, Mar 13, 2010.
  1. jayanthyk192
    Jan 23, 2010
    80
    i am using HD74LS164 for one of my projects.i activated the IC by give 5v to pi14 and grounding pin7.then i connected pin 13 to pin1 and shorted pins1&2 when i switched on the power supply all the LEDs i connected to the outputs switched on and when i gave 0 to pin 1 and when the clock went low all yhe LED's went low.can anyone tell me the problem?
    if possible give me a complete circuit to switch on the LED's one by one in a loop.
    thank you.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    post the schematic
  3. jayanthyk192
    Jan 23, 2010
    80
    i dont have any software to draw the schematic so i drew it with MS paint.
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    Ur circuit is wrong, try the attached diagram for a change
    Clock is at 1 kHz.
    when u trigger the leds will light one by one and when u off the trigger the leds will turn off one by one
    The LED resistors are 220Ω 0.5W
