Hello everyone. I am trying to program an STM8S003F3 I2C in master mode. I have setup up all of the registers, but when I start a transmission the start bit is sent, but both SDA and SCL stay low. The address is never sent. Here is part of the I2C code. Using the debugger I noticed the ADDR bit is never set and therefore it never gets past the while loop. It stays there forever. Does anyone what what I am missing in my code?
Code:
void I2C_Init(){
I2C->CR1 &= ~I2C_CR1_PE; // Disable peripheral
I2C->FREQR = 16; // value equal to clock frequency (16MHz)
I2C->CCRL = 80;
I2C->TRISER = 17;
I2C->OARH |= I2C_OARH_ADDCONF; // Has to be set to 1
I2C->CR1 |= I2C_CR1_PE; // Enable peripheral
I2C_Init();
I2C->CR2 |= I2C_CR2_START; // Send start condition
while(!(I2C->SR1 | I2C_SR1_SB)){}
dummy = I2C->SR1; // Read SR1 to clear SB bit
I2C->DR = 0x3D<<1; // Transmit address
while(!(I2C->SR1 & I2C_SR1_ADDR)){} // Wait until address transmission is finished
Clear_I2C_ADDR_Bit(); // Clear ADDR bit
