Well... since ACK is short for ACKNOWLEDGE, and is used to let the master know the slave is there and responding, all I can say is LDO.I found the easiest way to check that it was working was to send the start condition, then the address of the DS3231, check the ack bit, send stop condition. I looped this over and over and scooped the two lines.
Thread starter | Similar threads | Forum | Replies | Date |
U | pic16f690 - LCD works in proteus but not on breadboard | Microcontrollers | 7 | |
Help with PIC16f690 and pin address -- CCS C compiler | Microcontrollers | 7 | ||
Help with PWM and servo with Pic16F690 | Microcontrollers | 13 | ||
C | Timer 2 PIC16F690 | Homework Help | 8 | |
F | Need help with RTC DS3231 and PIC16F690 | Microcontrollers | 8 |
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
