I have no clue about verilog, can anyone help me turn this into VHDL?
Rich (BB code):
module i2c (
CLOCK,
I2C_SCLK,//I2C CLOCK
I2C_SDAT,//I2C DATA
I2C_DATA,//DATA:[SLAVE_ADDR,SUB_ADDR,DATA]
GO, //GO transfor
END, //END transfor
W_R, //W_R
ACK, //ACK
RESET,
//TEST
SD_COUNTER,
SDO
input CLOCK;
input [23:0]I2C_DATA;
input GO;
input RESET;
input W_R;
inout I2C_SDAT;
output I2C_SCLK;
output END;
output ACK;
//TEST
output [5:0] SD_COUNTER;
output SDO;
reg SDO;
reg SCLK;
reg END;
reg [23:0]SD;
reg [5:0]SD_COUNTER;
wire I2C_SCLK=SCLK | ( ((SD_COUNTER >= 4) & (SD_COUNTER <=30))? ~CLOCK :0 );
wire I2C_SDAT=SDO?1'bz:0 ;
reg ACK1,ACK2,ACK3;
wire ACK=ACK1 | ACK2 |ACK3;
//--I2C COUNTER
always @(negedge RESET or posedge CLOCK ) begin
if (!RESET) SD_COUNTER=6'b111111;
else begin
if (GO==0)
SD_COUNTER=0;
else
if (SD_COUNTER < 6'b111111) SD_COUNTER=SD_COUNTER+1;
end
end
if (!RESET) begin SCLK=1;SDO=1; ACK1=0;ACK2=0;ACK3=0; END=1; end
else
case (SD_COUNTER)
6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end
//start
6'd1 : begin SD=I2C_DATA;SDO=0;end
6'd2 : SCLK=0;
//SLAVE ADDR
6'd3 : SDO=SD[23];
6'd4 : SDO=SD[22];
6'd5 : SDO=SD[21];
6'd6 : SDO=SD[20];
6'd7 : SDO=SD[19];
6'd8 : SDO=SD[18];
6'd9 : SDO=SD[17];
6'd10 : SDO=SD[16];
6'd11 : SDO=1'b1;//ACK
//SUB ADDR
6'd12 : begin SDO=SD[15]; ACK1=I2C_SDAT; end
6'd13 : SDO=SD[14];
6'd14 : SDO=SD[13];
6'd15 : SDO=SD[12];
6'd16 : SDO=SD[11];
6'd17 : SDO=SD[10];
6'd18 : SDO=SD[9];
6'd19 : SDO=SD[8];
6'd20 : SDO=1'b1;//ACK
//DATA
6'd21 : begin SDO=SD[7]; ACK2=I2C_SDAT; end
6'd22 : SDO=SD[6];
6'd23 : SDO=SD[5];
6'd24 : SDO=SD[4];
6'd25 : SDO=SD[3];
6'd26 : SDO=SD[2];
6'd27 : SDO=SD[1];
6'd28 : SDO=SD[0];
6'd29 : SDO=1'b1;//ACK
//stop
6'd30 : begin SDO=1'b0; SCLK=1'b0; ACK3=I2C_SDAT; end
6'd31 : SCLK=1'b1;
6'd32 : begin SDO=1'b1; END=1; end
endcase
end
endmodule
