This is my first time posting so i hope i do this right.
i am trying to write and then read a value from a FM24C64 EEPROM but all i receive is 0xff.
I am using bit-banging routines that i have used before successfully.
I attached the bit-banging routines and the datasheet for the EEPROM.
here is my code that i am trying to use to do a simple read-write.
you will notice that in order to confirm that there is an ACK i placed them in a if-loop and checked with the deubbuger that it ran all the way through the code. and it did, but it still will only return 0xff.
i have a scope incase any data from a scope is needed.
but so far i have tried everything i can read on forums but cant seem to solve this problem!
to confirm that the EEPROM is responding and that the setup is ok i ran this code:
and the ADDRESS array had 2 values, address_write and address_read of the EEPROM, so i know that the EEPROM is ACKing at least the first byte.
i also attached the scope view of the function (in a zip)
as you can see, there is an ack at the first few commands, but when trying to read, after the address_lsb is sent, there is no ack!
i cant figure out why.
(possibly i misunderstand the scope)
I would really appreciate any and all help!!!
Rich (BB code):
unsigned char WRITE_READ(unsigned int address, unsigned char data_in)
unsigned char adress_msb, adress_lsb;
unsigned char data_out;
adress_msb = address / 256;
adress_lsb = address % 256;
// start write
unsigned char write_complete = 0;
while ( write_complete == 0 )
I2C_Start();
while ( I2C_Write_Byte(ADDRESS_WRITE) == 1 )
I2C_Start();
if ( I2C_Write_Byte(adress_msb) == 0 )
if ( I2C_Write_Byte(adress_lsb) == 0 )
if ( I2C_Write_Byte(data_in) == 0 )
write_complete = 1;
I2C_Stop();
// start read
write_complete = 0;
I2C_Start();
I2C_Start();
I2C_Start();
if ( I2C_Write_Byte(ADDRESS_READ) == 0 )
data_out = I2C_Read_Byte();
write_complete = 1;
I2C_Send_NACK();
I2C_Stop();
return data_out;
Rich (BB code):
j=0;
for (i=0;i<256;i++)
I2C_Start();
if ( I2C_Write_Byte(i) == 0 )
ADDRESS[j] = i;
j++;
