Hi all,
Stuck yet again I'm afraid! I've a BV4618 keypad display module which is giving me grief now, its probably simple but I've been going at it for hours now . A little bit of background, I've got a pic18f2523 on a board I had made up, until now it just had a eeprom on the I2C bus and was happy. The bv4618 module goes on the I2C bus and allows you to interface to a display and 4x4 keypad.
The display is working just fine, I can write to it clear the screen etc no problems. My problem starts when I want to read data from the keypad buffer. The module has a output that is driven low when there is data in the buffer, this works fine, with the pickit2 debugger, I can see I've sent a command to read data from the bv4618, data has come back to the pic and is in the w reg (number of bytes in buffer).
This is the receive code I'm using
The problem is after this I can't create a stop condition, if I add another generate ACK command I can get a stop condition but then can't create a start condition, it appears the slave (bv4618) is holding the sda line low.
I searched about a bit read another post on this forum and have tried disabling the i2c module after the stop bit and pulsing the scl line a few time before I try and get the start condition, still hangs!
Any input is welcome before I chuck the whole lot in the bin and get a pic with more i/o!
Cheers Geoff
Rich (BB code):
RX_BYTE
bcf PIR1,SSPIF ; Clear SSP interrupt flag
bsf SSPCON2,RCEN ; Initiate reception of byte
rx_wait
btfss PIR1,SSPIF ; Check if operation completed
bra rx_wait ; If not, keep checking
movf SSPBUF,W ; Copy byte to WREG
movwf datai ; Copy WREG to datai
bsf SSPCON2,ACKEN ; Generate ACK/NO ACK bit
rx_wait2
bra rx_wait2 ; If not, keep checking
return
Cheers Geoff
