hi ,
have anyone achieved an I2C between a master and slave , I have searched on the net but not satisfied .
please anyone have a 2way communication between a master and slave ?
I have written the following code in Proton , and it could move a message from the master to the slave , but i'm incapable of sending a message in the opposite way (from slave to master)
i have another question , where the address of the slave is checked (in hardware or in the software ) because the slave here is accepting every address ?
master
slave :
please any help , or code would be appreciable .
master
Rich (BB code):
Device = 18F4550
Xtal = 20
HBStart
SSPBUF=0
TXSTA.5=1 ' setting Transmit Enable Bit
RCSTA.7=1
RCSTA.4=1
Hserial_Baud 19200 ' Setting Baud rate
Symbol SMP = SSPSTAT.7 '1:enable high speed , 0: slow speed
Symbol CKE = SSPSTAT.6 '0 always for me
Symbol DATA_ADDR = SSPSTAT.5 '1:last byte was data, 0:last byte was address
Symbol P = SSPSTAT.4 'I2C Stop detection
Symbol S = SSPSTAT.3 'I2C Start detection
Symbol R_W = SSPSTAT.2 '1:read 0:write operation [m]1:inprogress 0:may not
Symbol UA = SSPSTAT.1 '1:sspadd need update [10bit only]
Symbol BF = SSPSTAT.0 'Buffer Full Status flag
Symbol WCOL = SSPCON1.7 'Write Collision Detectection
Symbol SSPOV = SSPCON1.6 'Receive Overflow Indicator bit
Symbol SSPEN = SSPCON1.5 'mssp Enable bit
Symbol CKP = SSPCON1.4 'SCK Release Control bit ???????????????????????? 1
Symbol SSPM3 = SSPCON1.3 '1111:[S10+INT],1110:[S7+INT],1011:[S IDLE]
Symbol SSPM2 = SSPCON1.2 '1000:MASTER F/4(SSPADD+1)
Symbol SSPM1 = SSPCON1.1 '0111[S10 NO INT]
Symbol SSPM0 = SSPCON1.0 '0110[S 7BIT]
Symbol GCEN = SSPCON2.7 ' General call enable bit
Symbol ACKSTAT = SSPCON2.6 '1:ack NOT receied,0:ack received (Master Transmitonly)
Symbol ACKDT = SSPCON2.5 '1:ack 0:nack (Master Receive mode only)
Symbol ACKEN = SSPCON2.4 'Acknowledge Sequence Enable bit (Master Receive mode only)
Symbol RCEN = SSPCON2.3 '1:Receive Enable 0:disabled (Master receive mode only)
Symbol PEN = SSPCON2.2 'Stop Condition Enable bit (Master mode only)
Symbol RSEN = SSPCON2.1 'Repeated Start Condition Enabled bit (Master mode only)
Symbol SEN = SSPCON2.0 'Start Condition Enabled/Stretch Enabled bit
Symbol S_GCEN = SSPCON2.7 ' General call enable bit
Symbol S_ACKSTAT = SSPCON2.6 'not used in slave
Symbol S_ACKDT = SSPCON2.5 '1:enable address masking,0:disabled
Symbol S_ACKEN = SSPCON2.4 '1:Enable address masking,0:disabled
Symbol S_RCEN = SSPCON2.3 '1:Enable address masking,0:disabled
Symbol S_PEN = SSPCON2.2 '1:Enable address masking,0:disabled
Symbol S_RSEN = SSPCON2.1 '[7bit]1:masking of sspadd<1> [10]1:masking of <0:1>
Symbol S_SEN = SSPCON2.0 'enable clock stretch 0:disable
Dim i As Byte
Dim t As Byte
Dim DataOut As String * 30
Declare Slow_Bus On
SSPADD = 49 '100kHz
SSPSTAT = 0b00000000
SSPCON2 = 0b00001000
SSPCON1 = 0b00101000
DelayMS 500
Output PORTB.7
i=-1
main:
Toggle PORTB.7
DelayMS 100
HBusOut 0b10100000,["master say hello"]
Toggle PORTB.7
DelayMS 500
GoTo main
slave :
Rich (BB code):
Device = 18F4550
Xtal = 20
Output PORTB.7
RCSTA.7=1
RCSTA.4=1
LCD_Interface 4
LCD_DTPin PORTB.4
LCD_RSPin PORTB.3
LCD_ENPin PORTB.2
'ADCON1=0eh
'Declare Hbus_Bitrate 100
Input PORTB.0
Input PORTB.1
'master
'SSPADD = 49
SSPADD = 0b11110000
'master:
'SSPSTAT = 0b00000000
'MASTER
'SSPCON1=0b00101000
SSPCON1=0b00101110
Symbol ACKSTAT = SSPCON2.6 '1:ack receied,0:ack not received (Master Transmitonly)
'SSPCON2=0b000000000 '4
'slave mode
SSPCON2=0b000000000 'enable stretch
Symbol SSPIF PIR1.3 'Parallel rad/write finish FLAG
Symbol SSPIE PIE1.3
Symbol GIE_GIEH INTCON.7 'GLOBAL Interrupts enable
Symbol PEIE_GIEL INTCON.6 'SIDE DEVICES INTERRUPT ENABLE
GIE_GIEH=1
PEIE_GIEL=1
SSPIE=1
On_Interrupt GoTo u:
Dim DataIn[30] As Byte
Declare Slow_Bus On
SSPADD = 0b10100000
SSPCON1 = 0b00111110
SSPCON2 = 0b00000000
Dim I As Byte
I=-1
Dim T As Byte
DelayMS 500
main:
' HSerOut [Bin8 SSPADD,"-",Bin8 SSPSTAT,"-",Bin8 SSPCON1,"-",Bin8 SSPCON2, 13]
' HSerOut ["main-", "-" ,Hex SSPBUF,"-" ,Bin1 SSPIF ,Bin1 BF ,Bin1 SSPOV,Bin1 WCOL,Bin1 S,Bin1 P,13]
DelayMS 100
HSerOut [Str DataIn,13]
Clear DataIn
DelayMS 100
Toggle PORTB.7
GoTo main
u:
If SSPIF =1 Then
T= SSPBUF
If S=1 And T <> SSPADD Then
Inc I
DataIn = T
SSPIF =0
SSPOV = 0
WCOL = 0
End If
If P=1 Then P=0 :I=-1
SSPIF=0
End If
Context Restore
