I would like to monitor the SDA line of a I2C bus to know when it goes high. I have to do this by tapping into an external cable that goes into a sealed box that houses the I2C CCA. The SDA and SCL lines are pulled up to 3.3V through 1K resistors. I found a LED at Radio Shack with a 3.3V forward voltage and 10 mA rating. I was thinking of attaching the LED between the SDA line and the 3.3V return but with a 1K ohm pullup resistor will the LED be bright enough to see?
There is a 24V wire in the cable that supplies power to the 3.3V power supply. If the LED between the SDA and return won't work, could I connect the LED as above, put a 3.3V zener in parallel with it so the SDA line won't go above 3.3V and then connect the 24V to the SDA line through a 2800 ohm .25W resistor? Any ideas would be greatly appreciated.
