i want use LED MR16 Dimmable lamps to replace the MR16 Halogen dimmable lamps
Discussion in 'General Electronics Chat' started by nbtte, Jan 25, 2010.
  1. nbtte
    Jan 25, 2010
    i want use LED MR16 Dimmable lamps to replace the MR16 Halogen dimmable lamps, but i don't know whether i should change anything of the circuit?
    Who can help me?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Can you provide some details about the lamps and dimming circuit?
    Datasheets would be great.
    Greetings,
    Bertus
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    A lot of ground was covered in this other thread.
    http://forum.allaboutcircuits.com/showthread.php?t=23611
    Use this thread to ask your question, this thread belongs to you alone. I'm referring you to the other thread as a reference.
    The other poster had a lot of Q&A sessions, he wasn't too happy with some of the answers.
    The short answer is it is unlikely you will be able to get satisfactory results using the built in dimmer. I could be wrong, but LEDs are not light bulbs. The way they light up when current is varied is very nonlinear. There is a technique called PWM that will vary a LED linearly, but it is totally different than the way typical dimmers work.
    I would assume the manufacturer matched everything else though, so the LED version should be a drop in replacement.
    Best advice is try it and see, if it doesn't work, then we'll be glad to work with you to make it right.
  4. PentodePuppy
    Member
    Aug 19, 2009
    12
