MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
There are quite a few on ebay for DC motor controllers, one or two offer bi-directional, otherwise you would need to do the motor lead reversal.
Max.
Max.
Don't post phone numbers -- unless you really want to get added to all kinds of telemarketer lists. Even if you do, please don't post your phone number on AAC because we don't want the bots to learn that this is a good place to go fishing.Feel free to call or text if easier .
MOD NOTE: Removed phone number.
The can is hard to crush if the can is in perfect condition and the applied force is applied exactly on axis. The smallest dimple in the side of the can reduces the force dramatically.How much force to crush a can? With a stabilizing board on top of a can to insure a flat contact, with a 5 gal. bucket centered over can, filled with water to about 2/3 full & added another bucket & filled until can shrunk
by 1 in. Total weight 49 lb. Looks like 110 lb. actuator should do. The expensive model comes with a slide pot. for which I see no need as cheap ?? one for $ 10 less has top & bottom limit switches.
You must not be looking very hard.I'm not seeing any 120v ac linear actuators?
Have you considered the mechanism needed to remove a crushed can before the next one gets crushed? A build-up of crushed cans could screw up the use of limit switches for the actuator movement.I'm going to have a gravity fed can loader where they are stacked on top of each other . I want it to crush one can and then the other one falls down and then the actuator will come back and crush that can
by Jake Hertz
by Duane Benson
by Jake Hertz
by Aaron Carman
