I want to operate a DC brake for crane hoist - KBPC3510 rectifier
PRAVEEN SHARMA
Joined Jan 1, 2016
Mods edit:
This thread was split form -- Full bridge rectifier.
Please don't hijack other member's post, now you have your own.
Hi everyone,
I want to operate a DC brake for crane hoist. Brake rating is 24V DC, 80W rating max. Can i use
KBPC3510 rectifier. What AC voltage transformer to be used. how much VA rating to be used. Please helpKBPC3510-3510-35A-1000V-Bridge-Rectifier.jpg
MaxHeadRoom
Joined Jul 18, 2013
28,702
Measure the resistance of the brake coil and this can then calculate the VA required.
A transformer va from your numbers is around 100Va.
24vac secondary, no Cap required.
Max.
Papabravo
Joined Feb 24, 2006
21,228
Transformers are labeled for AC voltages which are RMS (Root Mean Square). Given an RMS voltage, you multiply that by the SQRT(2) ≈ 1.414 to get the peak voltage. You need a little bit of headroom for the diodes in the bridge rectifier and a bit more if you want to use a voltage regulator.
So:
\(24= \sqrt{2}V_{ac} - 1.4\)
\(\left(\frac{24 + 1.4}{\sqrt{2}}\right)=V_{ac}\)
\(V_{ac} \approx 18 \text VAC_{rms}\)
If you want to use a voltage regulator then bump the AC voltage up a bit to say 20 VAC.
chuckey
Joined Jun 4, 2007
75
Depending on how the DC is being switched to the brake, it would be worth while to incorporate a back EMF diode or some sort of snubber across the switch.
Frank
panic mode
Joined Oct 10, 2011
2,761
you definitely need a diode across brake and this needs to be placed as close as possible to the brake coil (not 30m away or where PSU is). note, this diode need to be reverse biased (cathode to +ve side).
24VDC is industrial standard and you don't need to make own PSU, you can get cheap industrial PSU which will have approvals and other features that may be useful (like short circuit protection etc).
if you are making your own PSU, yes you can use that bridge rectifier, with up to 1000V and 35A it is more than big enough (an overkill actually - something rated for 60V and 5A would also be fine).
ian field
Joined Oct 27, 2012
6,536
Crane hoists usually use DC braking.
2 push buttons for up and down. each button is single pole changeover. both buttons pressed or both buttons released shorts the motor winding.
Just to get started - say both NC contacts go to battery negative, and both NO contacts go to battery positive. the motor is strung between the to moving contacts. Any time both switches are in the same state; both ends of the motor winding are connected to the same battery terminal.
34,468
Actually, you do want the diode at the PSU switch so it suppresses the spike from the wire inductance as well as the brake inductance.
Remember that the purpose of the diode is to provide a path for the inductive current when the switch opens, and that path includes the wire inductance.
But if you switch the AC voltage to control the brake then you don't need any added suppression diode since the bridge diodes will serve that purpose.
panic mode
Joined Oct 10, 2011
2,761
you can have both but if one must choose, imho it is better to have diode at the load. otherwise you are burning contacts and stressing insulation of the wires and load.
