I want to make a led blink
Discussion in 'The Projects Forum' started by jhawk100, Jun 2, 2013.
  1. jhawk100
    Jun 2, 2013
  2. LDC3
    Apr 27, 2013
    920
    160
    Actually, we could make it even easier for you. If you can tell us the type of connection your headset has to your phone, we could detect when your headset is 'on' and light the LED.
  3. jhawk100
    Jun 2, 2013
  4. jhawk100
    Jun 2, 2013
  5. LDC3
    Apr 27, 2013
    920
    160
    I was thinking that this might work.
    I didn't find a symbol for a stereo plug, but it needs to be placed on the right where the 3 wires are.
  6. jhawk100
    Jun 2, 2013
    sorry I have no idea what that means
  7. LDC3
    Apr 27, 2013
    920
    160
    Sorry I made a mistake. If resistors are used, then you will get cross talk between the microphone and the speaker. The connection to the jack may need to be changed as well.
    Does anyone see any problems with this?
  8. wayneh
    Sep 9, 2010
    12,396
    3,246
    If you want to stick with the manual switch, the circuit you need is very simple, with 4 components in series:
    1. Battery
    2. Switch
    3. LED (or 2-3 in in series)
    4. Resistor to limit current
    That's more-or-less what was in your picture but the resistor was not shown, probably because that LED strip had them built in. The choice of LED(s) determines the choice of the resistor(s). A typical LED may be rated to 20mA. It'll be plenty bright at half that, or 5-10mA. With 9V, you can put two LEDs in series with one resistor. Each LED will drop ~3.5V, so you probably cannot use 3 or they may not light once the battery ages.
    If 2 LEDs are not enough, you can add more parallel strings of two-LEDs-plus-resistor, as many as you like. A typical 9V battery might handle 5 strings pretty well if they are all less than 10mA.
  9. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    The LED you've pointed to on ebay looks to have a built in resistor and will work with a 3.6V to 12V supply so keep things simple and forget the detecting bit!
    All you need is the battery, switch and LED in series, forget the fuse.
    9V Battery+ > switch > LED+(Red) > LED-(Black) > Battery-.
  10. absf
    Dec 29, 2010
    1,493
    374
    The LED that you bought has a chip built-in that flashes the LED. It can accept 3.6 - 12V dc so no resistor is needed in series. The operating forward current is 30mA, so your wiring should be okay.
    But I think you should remove the black wire to the switch and just leave that tag NC (no connection). Your switch is probably a SPDT switch with common at the centre. If that's the case, your battery positive would be shorted to the negative when it is in OFF position.
    Allen
  11. dthx
    Member
    May 2, 2013
    194
    14
    JayHawk100.....
    Have you bought anything yet?
    If you have...or have not...let us know...
    It may seem complicated but what you want to do is simple.
    If you use a 9volt battery like your pic....you will need some way to attach a wire to the battery....cause the battery has no wires attached to it...(obviously)
    They sell a simple battery connector that clips to the battery and has wires attached to it. (Radio Shack)
    Then, just like PaulKTreg says (above)....
    Just connect everything in "a Line"...what these guys call " in series".
    Another words connect a wire from the battery ....to the switch.....to the led....and back to the battery....
    The wires can be of various lengths...
    You can twist the wires together and use a "wire nut" for the connection...
    Find a Radio Shack and see if the person in there can help you.....Occasionally they have someone behnd the counter that tinkers with electronics.
    Unless the LED that you buy has a "built in resistor" you wil burn it up.
    The one you showed us in the picture on EBay had a little bulge in one of the wires...that is were the resistor is located....they already put it in the wire...
    So if you get that one...or one like it...you dont need to worry about a resistor.
    If Ive made a mistake in any of my advice...someone will correct me.
    Hope that helps.
  12. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    I would use a flashing 14V LED a switch and a PP3 9V battery. This way you don't need a current limiting resistor and the circuit is literally three components wired in series.
