In post #10 I posted an ebay item that is virtually identical to the circuit in post #2 except it requires the switch added if you want reversal, you just wire it to the output.Ok sorry, Im confused, R u still using the first diagram???
It doesn't matter. The reversing switch is connected to the motor, not the speed control.Ok sorry, Im confused, R u still using the first diagram???
So...connect the LEDs to the switch.But I want to LEDs to "communicate" with the switch that changes the direction of the motor
Hi Aminnich,
I just registered here today.I'm the PCB fabricator in Shenzhen of China.
I can help you to make the prototype for 5 pcs for free,
you just need to pay the shipping cost.
Send me your PCB gerber file if you want.
Would I still need the potentiometer?Max.
The speed control controls speed. The reversing switch controls reversing. The potentiometer is part of the speed control. There is no potentiometer connected to the reversing switch. Adding a reversing switch will not remove the need for a speed control.Would I still need the potentiometer?
The Pot comes with the ebay unit to control rpm 0-max.Would I still need the potentiometer?
Sure. Just use the reversing switch we've been talking about since post #10.would putting a switch in the output change the direction?? It sounds like thats want I need
Ahh! So that's why this has been so difficult.I have little understanding of the schematic
You want to make a circuit but you can't read a drawing of the circuit.I want to make a circuit with a slow dc motor, a pot to change the speed of the motor, and a switch to change the dorection of the motor.
With this article in mind what are your turnouts using?hey guys, I am new to this thread, not necessarily circuits. I have took a clas in high school on this kinda stuff, but I forgot a lot of it. Now I'm starting a model train layout and I want to do something abnormal things to the layout (also saving some money) so here is my problem..... I want to make a circuit with a slow dc motor, a pot to change the speed of the motor, and a switch to change the dorection of the motor. Im using this for the turnouts. I have googled it, but haven't found anything, I don't even know if it can b done. Thanks for any help!!
Since you mentioned motors I assume #2? Electric trains have come a long way since 1957 when my Lionel set ran around the Christmas Tree.7. Powering Switches - Installing Switch Machines
Some switches come pre-wired and powered. You can also add power to manual switch machines with after-market motors. Model switches are generally powered by one of two devices.
- Twin-Coil machines use a simple twin-coiled electro-magnet to throw the points. These are inexpensive and commonly found in factory-powered switches. Disadvantages include a very fast action and high, though brief, Amperage draw.
- Switch Motors are small motors which move the points back and forth. Most are low-voltage and "stall" motors which draw a low current all the time to hold the points tight without burning out. These motors operate realistically and can often run for decades without maintenance, but they are generally more expensive than twin-coils.
I had MärklinElectric trains have come a long way since 1957 when my Lionel set ran around the Christmas Tree.
by Aaron Carman
by Jake Hertz
by Jeff Child
by Aaron Carman
