I want to make a circuit in which a bi color led changes color every time the circuit is switched on
fridodido
Joined Dec 27, 2014
18
blocco a spirale
Joined Jun 18, 2008
1,546
A webcam will not necessarily consume a great deal of bandwidth as you only require a very low refresh rate and the image, for the most part, is stationary.
fridodido
Joined Dec 27, 2014
18
Still, could there be a device which i originally mentioned which could glow with a different color each time it was powered on?
All other solutions look a bit complicated
MikeML
5,444
Can you see the generator out your window (we already established you cant hear it)? If yes, mount a lamp on the top of the generator ;)
My farmer neighbor operates an irrigation circle. It has a 75W incandescent lamp mounted on the center pivot. I can see that from over a mile away...
