I want to know which factor causes switch node transient level high in buck converter
Discussion in 'Power Electronics' started by Benengineer, Jul 5, 2016.
  1. Benengineer
    Feb 6, 2016
    101
    This is the circuit I have as follows:
    Because the output noise is out of limits 120mV(P-P), which is 140mV. I added a capacitor and resistor to parallel with D2. The noise level reduce to 80mV. That is what I want. It is good enough for this level.
    But this transient level is high. I want to know which factor causes this problem. My output is as follows:
    Also, what suggestion do you want to give me, for example, you can tell me output capacitor C6 or inductor L1 changed? Thank you,
  2. crutschow
    Mar 14, 2008
    13,454
    3,351
    Is that noise with no load or full load?
    You might try a larger output capacitor C6.
  3. Benengineer
    Feb 6, 2016
    101
    It is not full load. It is half load.
  4. DickCappels
    Aug 21, 2008
    2,743
    665
    Also along the lines of Benengineer's thought that the inductor may be running "dry", is that if you are drawing the expected current then you should increase the value of your inductor.
  5. Benengineer
    Feb 6, 2016
    101
    If inductor value is inreased, the peak current would be more smaller. I don't understand "inductor may be running "dry". "
    Here is my calculation for peak current and capacitor value.
    Based on buck, we can get ∆і = (Vin – Vo/2L) D Ts, this is how to design your L value according to your peak current.
    I measured the parameters:
    Vin = 24V Vo = 3.42V D= 11.5% Ts = 9.97uS
    L is known parameter which is 1mH
    ∆і = 0.012A
    The peak to peak voltage limits is 120mV. ∆V = 60mV
    Then, I got ∆V = ∆і*Ts/8C. I can get min C = ∆і*Ts/8∆V
    Cmin = 0.249uF.
    The circuit shows 150uF. I think it is big enough. Please let me know what is wrong with this ripple?
  6. crutschow
    Mar 14, 2008
    13,454
    3,351
    What is your load current?
  7. Benengineer
    Feb 6, 2016
    101
    This company is very wired. They don't know what load current is. Since this is a cable to communicate with others unit, I guess it is about 100mA.
  8. crutschow
    Mar 14, 2008
    13,454
    3,351
    Communication signals don't require significant power.
    Guesses don't count. Unless we know the actual load current we can't answer your question.
    Can you measure it?
  9. Benengineer
    Feb 6, 2016
    101
    This is just occupancy sensor and it is power by the cable which I showed many times in the circuit. So, I guess 3.3V is just power the unit itself. I measured input current at 24V is about 18.62mA. This is PCB board and I don't have a way to measure it. But I think it is less than 17mA. What is the reason you need to know the load? Do you have any theory to prove it?
  10. Benengineer
    Feb 6, 2016
    101
    When we design a buck, what if we don't have a load? Just think in this way, how to design switch frequency, what is network frequency. what about peak current, output peak voltage, design feedback loop. Duty cycle, how many poles, zero, how to adjust response with PID controller etc.
  11. Benengineer
    Feb 6, 2016
    101
    I learn those theory, but I don't know how to apply it. That is why I want to know about this.
    Thank you for your hlep
  12. crutschow
    Mar 14, 2008
    13,454
    3,351
    When you design a buck converter, you need to know the maximum load current to do the design.
    If you don't know that, then you need to know the actual load current.
  13. Benengineer
    Feb 6, 2016
    101
    Yes, we need to know the load. Since they don't know what the load is, I guess this is not critical parameter for them. It has been running for 20 years. As I told you, it is about 17mA at 3.3V. What suggestion can you give me?
    Thanks,
  14. Benengineer
    Feb 6, 2016
    101
    I think if this is out of the max load, the buck will run at discontinuous mode. Am I right?
  15. DickCappels
    Aug 21, 2008
    2,743
    665
    And with a discontinuous current you will see that little triangular pulse that you do not like.
  16. crutschow
    Mar 14, 2008
    13,454
    3,351
    If it's been running for 20 years, why is the noise suddenly a problem?
    DickCappels likes this.
  17. Benengineer
    Feb 6, 2016
    101
    Yes, that is why this company is wired. However, I measured the current and it is about 12mA at 3.3V.
  18. Benengineer
    Feb 6, 2016
    101
    When peak current is greater than its output current, then a discountious mode starts. The picture is follows.
  19. Benengineer
    Feb 6, 2016
    101
    The discountinuoius mode happends at
    I < ∆iɩ, which is 2L/RTѕ < D'(for buck duty cycle). That means the noise is bigger than the output if our assumatin is right. Is it possible for the diode reverse recoverary?
  20. crutschow
    Mar 14, 2008
    13,454
    3,351
    Diode reverse recovery current would generate a very short spike, not the longer spike you are seeing.
