i want to convert 1 millivolt to 1 volt.
Discussion in 'The Projects Forum' started by kamranraj, Jan 24, 2012.
  1. kamranraj
    Jun 4, 2010
    i want to convert 1 millivolt to 1 volt.plz give me circuit diagram.
  2. evilclem
    Member
    Dec 20, 2011
    118
    16
    Using an amplifier?
  3. wmodavis
    Oct 23, 2010
    737
    150
    Study up on how to make an op-amp circuit with a gain of 1000. Circuits abound.
  4. wayneh
    Sep 9, 2010
    12,368
    3,224
    If you're talking about 1mV over ground being amplified to 1V over ground, and you want to use a single supply, you'll need an op-amp that includes the lower rail. Not hard to find, but you may not get this property if you don't specify it.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    The frequency is not stated. An old 741 opamp has a gain of 1000 only at frequencies less than about 800Hz.
  6. Jon Wilder
    Oct 25, 2011
    23
    Perhaps if you would try ASKING rather than TELLING us to give you a circuit diagram...
    As was stated above, what you need is a voltage amplifier. The total amplifier gain would need to be a gain of about 1,000, which you can either do with multiple cascaded bipolar transistor or FET stages or you can do with a couple of cascaded op amp stages.
    You don't necessarily need a dual polarity rail power supply. You can do it with a single rail but you would have to capacitor couple the input and output. If you decide to go single rail and you need a 1Vrms output, you would need to have a minimum supply voltage of at least 3V.
