I want to build a 555
Discussion in 'General Electronics Chat' started by babafellow, Mar 28, 2008.
  1. babafellow
    Mar 28, 2008
    i need to construct a 555 timer which includes sounds sir
  2. babafellow
    Mar 28, 2008
    u just send only input and output wave what of d texts?
  3. babafellow
    Mar 28, 2008
    but i need a 555 timer which includes sounds
  4. babafellow
    Mar 28, 2008
    i need to construct an astable multivibrator
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I've moved these posts into their own thread.
    For clarification, do you wish to build a 555 equivalent from discreet components for educational purposes?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you got an LM555 datasheet? I believe it has block diagrams of the internal circuitry.
    What portion must make sound?
    And, by the way, an astable multivibrator includes, but is not limited to, an LM555. A clear statement of your project would be nice to have. If it is simply an audio frequency oscillator, then reengineering an LM555 is more effort than is necessary for the result. Three resistors, two capacitors, a lamp and an op amp will do the trick.
  7. Thomas.R
    Member
    Aug 16, 2007
    20
    i made one using this page. look for the one shot-operation
    Thomas
  8. Thomas.R
    Member
    Aug 16, 2007
    20
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    Hi Bill,
    An 8 ohm speaker has a peak current that is too high for your poor little 555.
    Connect a current-limiting resistor to limit the current to "only!" 200mA.
    Your LEDs won't light when they are connected upside down.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Picky Picky, actually I've built the former circuit many orbits ago, the 555 didn't get hot or anything, just wasn't very loud. I'll change the latter schematic to correct the LEDs, and I'll breadboard the former to verify (but I'll change the schematic anyhow for now).
    An old fashioned 1K to 8 ohm audio transformer would pick the volume back in any case.
    My Dad's favorite phrase about this time was "Turn it off". He liked his TV and we lived in the deep country, where anything could interfere. Thanks for pointing out my boner.
    I've noticed .gif files look a LOT better for these applications.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    With a 9V battery, the output of a 555 is about 7.5V p-p into a 1k transformer winding. Then the power is only 14mW. Like a little earphone.
    The output at 200mA is 4V p-p. Then an 8 ohm speaker in series with a 12 ohm resistor will have a power of 320mW, 23 times more than with the 1k transformer.
    A little LM386 power amplifier produces a square-wave of 1.1W when it drives an 8 ohm speaker with a 9V supply.
