I want some help with LM358 based differential amplifier
Discussion in 'General Electronics Chat' started by ishank3, Nov 19, 2015.
  1. ishank3
    Nov 19, 2015
    Hello Sir,
    I am new in the community. I need some help for my circuit.
    I am using LM358 for building diff.amplr circuit for making sensor offset zero.
    But, its not working properly. Offset of my sensor is 100mv. Can you please help me to build the circuit?
    Thank you.
  2. DickCappels
    Aug 21, 2008
    2,786
    676
    You don't give much information. Please post your circuit including the transducer.
    By the way the LM358's output cannot go all the way ground unless you help it with a 2.2k resistor (typical value) from the output to ground.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    Schematic, input voltage ranges, schematic, desired output voltage range, schematic....
    ak
  4. Bordodynov
    May 20, 2015
    673
    194
    See
    and
    absf likes this.
