I-v curve measurement CVS or CCS ?
Discussion in 'General Electronics Chat' started by Kih, Nov 7, 2011.
  1. Kih
    Nov 3, 2011
    10
    Hi All !
    I am going to measure the iv curve of a thermoelectric material(small resistance) using a curve tracer.
    However, I have no idea what are the cons%pros when using constant voltage source(or constant current source)......:confused:
    Or how to evaluate both methods......
    Hope you can share your experience~
    Thanks in advance!:D
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    As the current is always related to the voltage through the definition of resistance, take your pick. I don't have a curve tracer, but when I want the i-V characteristic of something, I hook it up to a DC power supply and run things in constant current mode and measure the voltage drop across the device. But this is just habit -- I could just as easily put a constant voltage across the device and measure the current. Probably one reason I use a constant current is I have a fairly-well developed engineering judgment that comes from letting the magic smoke out of things. This means I can usually spot when I'm running too much power through things before I damage it (OK, well, if you call me on it, the judgment comes more from those white burns on the whorls of my fingertips :p).
    Kih likes this.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    You have probably had at least one white (or red) "D" on a fingertip from touching a TO92 package at the wrong time. I know I have. :eek:
  4. DickCappels
    Aug 21, 2008
    2,782
    675
    If the resistance of your thermoelectric material changes with temperature, you will probably want to sweep through the IV curve manually, going very slowly so that the thermal lag inherent in the device does not distort the curve. Of course going very slowly would mean that a scope with infinite persistence would be beneficial. You can also sweep through the IV curve more quickly and compare that with the slow curve to get an idea of the thermal lag inherent in the device.
    The circuit at the URL below was intended for very small PTC thermistors and the occasional diode and is limited to about 50 ma and 2.5 volts. You might gain some inspiration for your own circuit from it.
    http://cappels.org/dproj/CURVE_TRACER/CURVE_TRACER_MANUAL.html
    Kih likes this.
  5. Kih
    Nov 3, 2011
    10
    Thx
    Very useful !~
  6. Kih
    Nov 3, 2011
    10
    agree . I can always take a look at the current so that i can know how much power is absorded by the device....
