I should charge battery at 13.5 volt but I need to avoid initial High
Discussion in 'General Electronics Chat' started by gpezzella, Jun 7, 2012.
  1. gpezzella
    May 7, 2012
    Hello
    I should charge battery at 13.5 volt but I need to avoid initial High Current.
    Is correct my solution?
  2. #12
    Nov 30, 2010
    16,665
    7,310
    Yes but...You will need more voltage to allow for the volts the regulator chip uses. About 2.75 extra volts.
