For the LED:
Optoelectronics > LEDs - <75mA, Discrete
Optoelectronics > Infrared Emitters
For the IR sensor:
Sensors > Optical - Photo Detectors - Photodiodes > choose 700nm+
Sensors > Optical - Photo Detectors - Phototransistors > choose 700nm+
<edit> Note that you can use IR LEDs as OK sensors. They are better than crude, but need to be lined up to within the LEDs optimal emission angle.
What is the project?
Is it something an optical interruptor may be suited for?
A 38kHz modulated Tx/Rx?
Rangefinding?
Need more info to give any sort of useful answer other than generic solutions.
Aren't they I/R? Would that work with a spinning board? Where do I get the receiver end? Is that just a regular I/R sensor?If you used a standard 38kHz Remote receiver package, mount it near the hub of the clock, and the signals can be sent to the same PIC.
Right Angle mount 38kHz receiver w/decoder. For transmitter, get a $9 universal remote and define your own codes.
Yeah, that would be an IR receiver, but if you mount it close to the hub, it will spin in a very small circle, I wouldn't think polarity would be an issue unless you are using a laser IR emitter.Aren't they I/R? Would that work with a spinning board? Where do I get the receiver end? Is that just a regular I/R sensor?
by Duane Benson
by Jake Hertz
by Duane Benson
by Duane Benson
