I&Q Modulator questions....
Discussion in 'Wireless & RF Design' started by Fovakis, May 22, 2013.
Thread Status:
Not open for further replies.
  1. Fovakis
    May 14, 2013
    23
    Hi. I cannot understand the I&Q Modulator...
    I am reading this one of mini circuits..http://217.34.103.131/pdfs/ZFMIQ-10M.pdf
    It has I and Q inputs...and it write (DC to 2MHz) freq for the input..
    1)is the I and Q analog signals or bit stream ?If is a bit stream how can it has 2MHz frequency?
    2)The I&Q Modulators as i understand make QPSK/8QAM/16QAM etc modulation..so the message I and Q must be bit streams (symbols basic) and carrier analog signal..right?
    3)The output of a I&Q Modulator is exactly like the output of a AM-Modulator (?)...USB, LSB , carrier...what is going on here?
    George
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
  3. Fovakis
    May 14, 2013
    23
  4. Motanache
    Member
    Mar 2, 2015
    106
    5
    The discussion is older. If someone are interested in this discussion I can explain.
    Two sinusoidal modulated in amplitude and with 90grd phase difference are sums.
    We obtain a complex wave modulated in both in amplitude and angular.
    At the reception Costa's loop must keep in phase........
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Did you notice the warning?
    This is an VERY old thread.
    Bertus
Thread Status:
