I/O ports in PIC18f87J90
Discussion in 'Embedded Systems and Microcontrollers' started by RG23, Oct 21, 2011.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I am using PICDEM LCD2 development board with PIC18f87J90 controller
    I intend to use only two inputs for up and down counter
    I defined the ports as follows:
    clrf PORTB
    movlw 0xC0
    movwf TRISB
    for using PORTB 7 and 6 as inputs
    When I make these changes in my program I am not executing up and down correctly
    I am using LUMEX LCD where supply voltage for logic is 5V.
    I provide 5V for display VDD using voltage regulator
    But when I check the voltage on PORTS B 6 and 5 it is 2.5V and 1.78V respectively
    Also Vcc on the board for PIC18f87J90 is 3.3V
    If anyone has an idea please let me know
  2. RG23
    Dec 6, 2010
    301
    Switches are already connected to Port B 7 and 6 on the development board.
    Hence I configure them as inputs
    I hope I made my question clear
  3. PRS
    Aug 24, 2008
    989
    35
    I am a novice at PICs, and so I don't want to offend you by calling your attention to things you probably already know. But did you zero ANSEL such as to make the pins you are using digital?
    Is your LCD using TTL? If so, you need a ucontroller with 5 volt I/O.
    If you are supplying the PIC with 3.3 volts, it only has 3.3 volts available on its I/O pins.
    I hope something I said helped.
  4. RG23
    Dec 6, 2010
    301
    I got the up and down functions working using the switches on the development board but there is something strange happening out there
    Actually there are four switches connnected to PORTB pins 6 & 7 and to PORTA pins 6 & 7 on the board
    I am using PORTB,6 for down and PORTA,6 for up
    I declare the ports as follows:
    clrf PORTA
    movlw 0x40
    movwf TRISA
    clrf PORTB
    movlw 0x40
    movwf TRISB
    When I define the ports as above the up and down buttons do not work
    In place of 0x40 for TRISB when I put 0xC9 they function as required
    I don't understand the reason behind it
  5. RG23
    Dec 6, 2010
    301
    Also when I try to configure PORTA,7 as up button switch and make the necessary changes to TRISA, it doesn't work
    Can anyone help me out in that too?
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Your change, movlw 0x40 ("b0100 0000"), is setting Rx6 ONLY as input.
    When the program uses 0xC9, the bits on the port are b1100 1001
    (I added spaces between each nybble above for easier reading of Hex digits)
    Since you say the counter works with 0xC9, and doesn't with 0x40, even though both have Rx6 set as input, take a look at the board schematic as well as the rest of your code to see what all connections and requirements are.
    Depending on what is connected, you may be disabling inputs required by the program/hardware.
    Since Rx6 is already set for input, why are you clearing the rest of the bits?
    A good way to make sure a pin is set as you like without disturbing the port is to AND the bit you want set with the existing value.
    As for the voltages, you will only get 3.3V out, since the J says it is a 3.3V uC. You can boost that output up to 5V with a transistor, though it would invert the output state.
    Lastly, Look at the Datasheet first, to make sure there isn't an on chip peripheral already blocking that port from another use without configuration changes.
