Hi everyone,
I need some advice on I/O connector ports.
Basically I have a circuit mounted within a case that requires input and output ports for exterior devices such as solenoid valves, thermometer probes and motors.
I will need some kind of sockets that can be mounted on a panel of my case, then a plug that will be connected to the appropriate device cable that will slot into its appropriate socket.
The connectors will need to be IP65 or above rated.
Any ideas what type of connectors I am looking for?
If it helps, I should inform you that I am from the UK.
Thank you for your time,
Rob
Rob
