Agreed.The probe was likely an ultrasonic, if you heard the blood flowing.
Doppler is typically used for blood flow probes.
[ed]
http://en.wikipedia.org/wiki/Medical_ultrasonography
[/ed]
Squirrsshhhaafllooop I believe..
I think the OP got more than he/she bargained forSo did we scare the OP away?
A day or so late & no OP, but why waste good usless information: Homemade geophone [seismometer- accelerometer ] consisting of 2 1/2 in 8 ohm speaker with 3 pennys glued to center readily detected light caugh, about 20 mV PP.
thank you for your information, but what type of accelerometer chips should i get?Attach a couple of accelerometers to a belt that mom is wearing, and connect them to a microcontroller that has been programmed to log acceleration as strong as a kick.
You can buy little solid state accelerometer chips fairly inexpensively, and a belt-mounted microcontroller could log to an SD card to track the time and characteristics of the events.
Somebody would have to design and wire up the circuit, and write the microcontroller program, which would not be trivial, and somebody would need to figure out how to come up with a threshold motion so you're not logging every motion that mom makes.
But I'll bet it would work!
Im still here Mr. Marsden. I went around to ask about your idea of using microphone, but they didnt seem to get what i mean..So did we scare the OP away?
If you are referring to the "microphone" being described in posts #17, 18, 27, and 29, it is really a speaker that is converted to microphone use. Consider a speaker with a coil on the cone and a magnet. As the cone is made to move by vibrations, a small voltage will be produced as the coil moves through the magnetic field.There is a building near my place, where it's mainly sell electrical stuff, and so i went there and ask from shop to shop about this microphone thing,but no one there seems to get what i mean.
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
