I Need Your Help....addendum
Discussion in 'Wireless & RF Design' started by KL7AJ, Mar 25, 2015.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,047
    295
    I suppose I should have prefaced my experiment solicitation with the following:
    How many folks here know how to make an antenna impedance measurement (R+jX)? (This includes any available means, Antenna analyzer, noise bridge, RX bridge, or other means).
    If we have a number of folks who can answer in the affirmative, we can proceed with the experiment.
    Stay tuned!
    Eric
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I can make the measurement, but I have no use for the prescribed antenna. I can measure one of my existing antennas that would be close, a 40M inverted V. It should be close to 67', but I'd have to measure it.
    Try posting on Dan Romanchik, KB6NU's, Ham radio blog.
    http://www.kb6nu.com/
    A lot of those guys have the time and equipment.
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Hi Dan:
    Can you lower the antenna to the ground and take a measurement? That would be great.
    Thanks!
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I will take the measurement:
    Antenna type: 40M Inverted V resonant in the General Class Phone Band, 7.225 to 7.300
    Length (including center insulator) 60' 8"
    Code (Text):
    1.
    2. MHz      Z         ||Z||
    3. 7.000  6 + j13  14.32∠65.22
    4. 7.050  6 + j12  13.41∠63.43°
    5. 7.100  6 + j12
    6. 7.150  5 + j12  13.00∠67.38°
    7. 7.200  5 + j10  11.18∠63.43°
    8. 7.250  5 + j10
    9. 7.300  5 + j10
    10.
    Is that sufficient or do you need more points?
    I'm not Dan, but he is a good friend of mine. Send him an email or post on his blog.
    KT8TD
  5. KL7AJ
    Nov 4, 2008
    2,047
    295
    Assuming that antenna is lying on the ground, you have VERY good ground conductivity there. If not, something's definitely shorted!
    Thanks...data recorded.
    Eric
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    Oh...one other thing...can you give me a description of your terrain?
    thanks!
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That's interesting since Florida is mostly sand it supposedly has worse conductivity than my norther QTH in Michigan. It was laying flat on the ground with the feedline perpendicular to the axis of the antenna. I've been operating QRP with somewhat mixed results. I missed K1N on Navass Island, but easily worked Europe, Africa, the Carribean, and South America in the CQWWRTTY and NAQP events in February.
    The antenna is constructed with insulated Flexweave and only the connector shell was touching the grass.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The terrain is basically flat with a slight upslope to the north. We are surrounded by tall pine trees. Altitude 38' ASL
    I'll PM you the Lat/Long coordinates.
    KT8TD
  9. KL7AJ
    Nov 4, 2008
    2,047
    295
    Grazzi! You have fired off the first shot in this grand experiment. :)
    Also, just for the record, what instrumentation did you use?
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I used a Palstar ZM-30 Digital Antenna Bridge.
  11. KL7AJ
    Nov 4, 2008
    2,047
    295
    Just to be sure you don't have an impedance inversion....was your meter right at the feed point, or did you have coax in between?
    Papabravo likes this.
  12. KL7AJ
    Nov 4, 2008
    2,047
    295
    You're probably familiar with this chart. This is what I use to "backwards engineer" the reflection depth
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The meter was at the end of the coax. I can repeat the measurement with out the coax.
    I've never seen that chart before. Would an explanation be to much to ask?
    New Data
    Code (Text):
    1.
    2.    SWR   Mhz       Z
    3.    3.4   4.450  187 + j0
    4.    6.0  15.260  133 + j148
    5.    6.5  26.300   64 - j125
    6.
    7. MHz      Z
    8. 7.970  670 + j0
    9. 8.000  670 + j0
    10. 8.100  670 + j0
    11. 8.200  594 + j0
    12. 8.400  525 + j0
    13. 8.600  525 + j0
    14. 8.800  465 + j120
    15. 9.000  417 + j189
    16. 9.200  374 - j233
    17. 9.400  337 - j260
    18. 9.600  306 - j273
    19. 9.800  278 - j282
    20. 10.00  254 - j283
    21.
    The first three lines are asking the instrument to find the minimum SWR in the ranges 1-10,10-20,and 20-30 MHz. The remaining data was taken by starting at 7.000 MHz ( the bottom of the 40 M band) and going up until I could find actual readings. If the impedance is greater than 600 Ohms it justt says ">600"
  14. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yes...if you can remove the coax, that will remove a big source of error.
    The chart shows the expected radiation resistance VS height of a dipole above perfect ground and above real ground (the dashed portion) in wavelengths. There's also a line for vertical antennas,which you can ignore.
  15. KL7AJ
    Nov 4, 2008
    2,047
    295
    By the way...if you have the time, could you also measure the antenna at precisely the third harmonic? You should get 0 reactance somewhere around 21.4 MHz or thereabouts.
    Thanks!
    Eric
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    3ed Harmonic data
    Code (Text):
    1.
    2.    MHz     Z
    3. 19.500  93 - j201
    4. 19.750  86 - j194
    5. 19.990  84 - j191
    6. 20.000  84 + j191
    7. 20.200  84 + j191
    8. 20.400  78 - j184
    9. 20.600  77 - j182
    10. 20.800  72 - j177
    11. 21.000  71 - j177
    12. 21.200  72 - j174
    13. 21.400  68 - j168
    14. 21.600  65 - j167
    15. 21.800  66 - j165
    16. 22.000  62 - j160
    17.
    Sorry the resolution of the DDS is 10 kHz. Was the sign flip between 19.990 and 20.000 expected? Is that the actual third harmonic.
  17. KL7AJ
    Nov 4, 2008
    2,047
    295
    I'd expect something a lot closer to 0J somewhere near resonance. Did you try redoing the 40 meter readings without the coax?
  18. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As I explained in the second set of readings the instrument shows ">600", meaning greater than 600 Ohms impedance for the entire 40 M band. I moved up from there to see if there were meaningful readings. Maybe I should have moved down from there to see if there were meaningful readings. I've put thing away for the night but I can do lower than 7 MHz tomorrow.
  19. KL7AJ
    Nov 4, 2008
    2,047
    295
    Roger that.
    Well, thanks immensely! We'll see how this compares to my modeling
    73!
    Eric
  20. KL7AJ
    Nov 4, 2008
    2,047
    295
    Hey!
    Just for your information (no need to measure anything now) your measurement at 4.45 MHz is right on the money, according to NEC modeling!
    So, this shows your method is good. When we get a chance, we can focus around that region!
    Eric
