I need to generate 12V from a motor
Discussion in 'General Electronics Chat' started by Rubi Adams, Dec 27, 2014.
  1. Rubi Adams
    Dec 26, 2014
    Maybe you can help me with this:
    I have the motor NC5475B motor rated from 3.5 to 24 V
    is this just the Voltage Operating Rnage (input voltage) and I just can turn on a LED (3V) .... but noting above that voltage.
    why is not possible to have similar voltage output, producing the mechanical movement?
    I have read about the "disadvantages of a mechanical commutator" and about the "reversibility principle" (a little)... but I still don´t understand.
    ¿There are a converter or smart table to know how much output Voltage I can obtain from a typical motor?
    ... I Would like to have an output voltage of 12V from a motor-generator not expensive. (less than $100 dlls) Is that possible ?
    KIND REGARDS!!!!
  2. blocco a spirale
    Jun 18, 2008
    1,460
    370
    How fast are you turning the motor? Have you checked the open-circuit voltage with a meter?
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    That appears to be a DC brushed motor, the voltage out should be proportional to the rpm, IOW, if the motor is rated at 24vdc and 2000rpm, back feeding the motor at this rpm, (2K) should produce `24vdc, or 1k for 12vdc..
    Max.
    #12 likes this.
