I need to find a regulator IC for a DC circuit
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 1, 2009.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    I need to find a regulator IC for a DC circuit. LM317 is ideal for this but my in-put voltage goes up to 100V sometimes. so LM317 cant be used for this because it’s working voltage is 4-40V. Please tell me suitable regulator IC which works just as the LM317 for this circuit.
  2. Xantor123
    Nov 1, 2009
    If the 100V are transient spikes you can use a resistor/zener in front of the LM317 to clean it up.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    What will be your output voltage?
    What will be the current needed?
    Greetings,
    Bertus
  4. ranatungawk
    Oct 30, 2008
    147
    out put 38V/40mA
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Then you could try a TL783.
    See datasheet.
    Greetings,
    Bertus
  6. ranatungawk
    Oct 30, 2008
    147
    Thanks a lot for the knowledge you are sharing ..
    if so can I use TL783 instead of LH317 without changing other components in my circuit?
    (can I replace blindly ?)
