The lines coming from the pole are 220VAC. This is a 3 wire circuit, having two 110VAC lines relative to neutral. The two hot lines are 180 degrees apart, so you get 220V between them. In the distribution (breaker) box, the two 110V lines get distributed to various circuits in the house. 220V goes to things like air conditioners, electric ranges, clothes dryers, etc.I don't know where I got that from. I throught I was reading something about the waves were 180 degrees out of sync. But that must be something else like through a transformer or something.
The only place in the entire world that i've seen this happen is on an aircraft carrier.I don't know where I got that from. I throught I was reading something about the waves were 180 degrees out of sync. But that must be something else like through a transformer or something.
