Your post is quite ambiguous.HI all
iam a beginner for using this software so i need the source for software please .
best regards
maher
Are you asking for the source code for the Visual Studio C++ compiler?HI all
best regards
maher
Unfortunately, you need Windows XP with SP2 for that. Other alternative is to use DGJPP, or Dev-C++ for Windows programs. Both use GCC (GNU Compiler Collection) and have options for C99 compliance. They are also available for Linux as well.You want to look here:
http://www.microsoft.com/express/download/#webInstall
That is Microsofts Visual Studio 2008 express edition...it's free but doesn't come with all the trimmings...
VSE2008 also works on Vista. Earlier versions of Windows are supported by VSE2005.Unfortunately, you need Windows XP with SP2 for that. Other alternative is to use DGJPP, or Dev-C++ for Windows programs. Both use GCC (GNU Compiler Collection) and have options for C99 compliance. They are also available for Linux as well.
They have shared-source licence agreements available for developers where portions of source code are shared between MS and collaborating companies/developers. I doubt, unless you are someone can be profitable, MS would give access to any source code.If you want the source code of Visual C++, you won't get it. As far as I'm concerned, Micro$oft never released open source software.
