I need some help with these DC motor questions
Discussion in 'General Electronics Chat' started by olliemax1, Apr 26, 2016.
  1. olliemax1
    Apr 26, 2016
    I have a few questions about DC motors, would anyone be able to answer them?
    how does current flowing through the coils generates a magnetic field
    How does Switching the current change direction of the field
    as the coil rotates the commutator changes the direction of the current
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    The questions are a little vague, DC P.M. or wound field motor? The current in the armature produces a magnetic field from the iron core it is wound on.
    The field in the armature reacts with the field whether the field is P.M. or wound, the strength of the field and applied voltage decides the rpm of the motor.
    The motor also generates a BEMF which opposes the applied voltage and will increase to a level which will almost equal the applied voltage, this will decide the resultant rpm level.
    For more insight study Flemings right and left hand rule.
    Max.
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,264
    222
    let's assume a DC permanent magnet motor.
    Your first two questions can be answered with Ampere;s Law: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/amplaw.html
    Without a commutator, the shaft would get "stuck", It effectively says move here and when your here, move to the next position, so the motor rotates.
