I NEED HELPPPPPPP!! (ring modulator for AM)
Discussion in 'Homework Help' started by gogetta, Nov 29, 2014.
  1. gogetta
    Nov 29, 2014
    5
    I need the design in Multisim for attached problem....on paper is good enough that i can simulate in multisim..
    THANK Y'all
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    A ring-modulator is designed for Dual Sideband-Suppressed Carrier modulation.
    Make it work that way.
    Then see what happens when you give a DC offset on the modulation signal.
    Now show what you have done.
    Bertus
  3. gogetta
    Nov 29, 2014
    5
    I have come up with the following design so far in Multisim.....Can you please guide me about missing components ( diodes, summing amplifiers etc.)
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The circuit you show has nothing to do with the ring-modulator:
    Here is the original question:
    I do not see any diodes and balanced transformers in your circuit.
    Bertus
  5. gogetta
    Nov 29, 2014
    5
    Exactly thats where I am stuck and needed help......Can you break it down for me.....I am being asked to modify a ring modulator to transmit AM and not jujst DSB-SC.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Did you see my remarks in post #2?
    Bertus
  7. gogetta
    Nov 29, 2014
    5
    yes I did..... so you are saying I can construct a simple ring modualtor (for DSB-SC) and give it DC offset on modulation signal??
    THANKS again
  8. AngelGdo
    Nov 30, 2014
    Hey!
    We're in the same boat! Literally, I'm working on the same project!
  9. AngelGdo
    Nov 30, 2014
    I think your design should look a little more like this:
    Let me know if you notice any issues with my design, or if you think of an oscillator that can be used to generate 2Vpp @ 10KHz
