I need help!
Discussion in 'Homework Help' started by Ape_Link, Sep 9, 2014.
  1. Ape_Link
    Sep 9, 2014
    Hi guys! My name is Daniel. I'm new to this website. I'm taking Electro-Mechanical Engineering Technology (Automation and Robotics), and the class I'm struggling on is Mechatronics 2. The question is to "sketch a circuit diagram that works as described below: When the proximity sensor senses a target, a light is energized immediately. The motor starts after a 5-second delay. When the target is removed, both the light and motor turn off." Now, I'm not to good in line diagrams so, I was asking for some assistance.
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    You could just draw a processor with one input and two outputs but are there any conditions on what components you need to use?
  3. MaxHeadRoom
    Jul 18, 2013
    10,855
    2,525
    I agree, you need to state what type of control, simple discrete hard wired components or PLC or other means allowed?
    Max.
  4. Ape_Link
    Sep 9, 2014
    Ya. The components are a proximity sensor with relay module, a pilot light module, a timer module, and a motor. It's also hard wired.
  5. pwdixon
    Member
    Oct 11, 2012
    488
    56
    So you can or can't use additional parts?
    If no additional parts then you will need to provide much more info on the actual parts you can use.
