look the following circuit that's for basic ALUGo to study 74LS181, it will help you some more from the very basic.
What are we supposed to be looking at or for?look the following circuit that's for basic ALU
The reason that your circuits are useless is because you won't take the time to consider what it is your circuits are supposed to do.I was trying to make circuit from morning . I made different circuits but I don't understand why thats circuit are useless
now I have decided. at night , in my dream I will ask to god, why I am not making right diagram If he will make circuit for me then definitely I will post the diagram here
I am feeling irritated , nervous,tired and funny .
Ok, you have the ALU now, and then you have to adding the ram as 74LS89(64 bits x1) or HM6116(2Kb x8) or some others you like.look the following circuit that's for basic ALU
He has the ALU? Sure doesn't look like it to me. It would appear that he thinks that using a CD4008 as an adder in one place and a subtractor in another place is done just by labeling one "ADDER" and the other "SUB". And that there is some meaning to the OR of the Carry-Out bits of the two adders, at least one of which is not being used. Then there is the issue of the numerous unconnected input pins. I'd be interested in the reasoning that leads to using a different logic operation on each pair of input bits.Ok, you have the ALU now, and then you have to adding the ram as 74LS89(64 bits x1) or HM6116(2Kb x8) or some others you like.
You may draw the blocks to show what you want in your CPU, and design one block by one block.
Yeah, that is ALU, a simply ALU, how complicated that you want him to have one, if he felt that is too simple then he can adding some more functions, do you respecting him to design a ALU like 8051 or 8088 or something like that, he have to building all the structures and modify later.He has the ALU? Sure doesn't look like it to me. It would appear that he thinks that using a CD4008 as an adder in one place and a subtractor in another place is done just by labeling one "ADDER" and the other "SUB". And that there is some meaning to the OR of the Carry-Out bits of the two adders, at least one of which is not being used. Then there is the issue of the numerous unconnected input pins. I'd be interested in the reasoning that leads to using a different logic operation on each pair of input bits.
And it makes little sense to go adding RAM when he still has no plan for how to fit the addressing and data paths into a coherent ISA.
I want to add static ram 32K , seven general purpose registers , accumulator and temporary register. I am using Ic 62256 for static RamOk, you have the ALU now, and then you have to adding the ram as 74LS89(64 bits x1) or HM6116(2Kb x8) or some others you like.
yes I want to start with simple circuit than I will modify laterhe have to building all the structures and modify later..
You can using one 62256 for data ram and another 62256(or HM6116,or 6264) for accumulator and other resisters, or you want to buy some old DRAM, but if you using DRAM then you will need the refresh circuit for DRAM.I want to add static ram 32K , seven general purpose registers , accumulator and temporary register. I am using Ic 62256 for static Ram
I am using proteus software do you tell me which Ic is use for general purpose registers , accumulator and temporary register
First I want to make design on software. after that I will show you design when you will verify design then I will buy some Ics.You can using one 62256 for data ram and another 62256(or HM6116,or 6264) for accumulator and other resisters, or you want to buy some old DRAM, but if you using DRAM then you will need the refresh circuit for DRAM.
I got 62256 maybe over 100 pcs.
74HC244 for tri-state inputs.First I want to make design on software. after that I will show you design then I will buy some Ics.
I did search on google and I read some good material
74Hc373 octal latch
62256 static Ram
74HC138 3 to 8 decoder
as you said I am using 62265Ics for accumulator and other registers
I need something or its enough for simple circuit
many experts say whenever you going to design complex circuit start with simple circuit and then Add more function, select some component than make small circuit ,then add more component and increase complexity of circuit74HC244 for tri-state inputs.
74HC373 -- maybe you can check 74HC573(pin to pin in/out), the pins arrangements are more easy for layout.
You can decide how complicated of the CPU, you may refer to the internal structures of 8051 or some other uC or CPU.
I'm not sure the whole picture you want, but if you want the CPU can run then you still need an EEPROM, an oscillator circuit for crystal.
I have made some connection
If the diagram 1 does make any sense then I want to modify that diagram ?
That was my experience and it also into my DNA.many experts say whenever you going to design complex circuit start with simple circuit and then Add more function, select some component than make small circuit ,then add more component and increase complexity of circuit
I am following this advice for batter result .
In the beginning that I hope you to reach to this step, now you already reached here, so you have to start over from the beginning back to the software as op code and registers.I am just trying to make for block diagram with connection
I am using following component
Program memory
data memory
register R1
Accumulator
temporary register
instruction register
program counter and Alu is not present in this diagram but I have already design ALU
I don't understand the connection
I have experience about assembly code , I have assembler 8051 IdeDo you have any experience about the assembly language, if you didn't then you better start to study a easy one as 8051, and don't talking about the C code here, c code can't leading you to the target.
I don't care how simple the ALU is. I do care that, however simple, that it has a chance of working. Have you LOOKED at the ALU that is proposed? Most of the parts aren't even connected!Yeah, that is ALU, a simply ALU, how complicated that you want him to have one, if he felt that is too simple then he can adding some more functions, do you respecting him to design a ALU like 8051 or 8088 or something like that, he have to building all the structures and modify later.
When he adding the ram and considering the data and address and adding some control unit then it will be helpful to reaching to the target more easier.
I should say that you offering a good idea, if the TS accept what you are talking about that's good, it is depends on the TS, you should persuading him to do.I don't care how simple the ALU is. I do care that, however simple, that it has a chance of working. Have you LOOKED at the ALU that is proposed? Most of the parts aren't even connected!
I still strongly recommend that he work through the Nand2Tetris project. You want a simple ALU, that's about as simple as it gets. A 16-bit Adder, without carry-in or carry-out, and a 16-bit bitwise AND. A few MUXes and inverters to selectively zero or negate the two 16-bit inputs and the output and that's it. The first project in N2T is basic logic blocks starting with the NAND and building everything else from that. The second project ends with the construction of that ALU. The third builds up counters, registers, and RAM building from the D-type FF and the logic blocks from the first chapter. The fourth introduces machine language and constructs a simple instruction set architecture (ISA). The fifth builds a CPU and then a complete system architecture based on the ISA. All five projects can be done in about four hours.
I have read top five pdf file link https://www.google.co.in/?gws_rd=cr,ssl#q=nand2tetris pdfAlthough I suspect I know where this will go, I would recommend that you work through the first several projects in the Nand2Tetris project described in my blog:
I don't understand what do you mean , If you are asking , how do you make instruction set than I can explainwe can't do much for you until you more fully define your instruction set architecture.
thanks for your help. I have already read lot of theory . And I just want to understand only one topicsHello,
The following pages of the EDUCYPEDIA contain each a lot of links on the diverse digital topics:
Arithmetic circuits
CMOS technology
Codes & decoders
Converters
Counters & registers
DAC/ADC types
Digital logic
Digital theory
Flip flops
FPGA Design
Memory
Number systems
Sigma Delta Conversion
Technology
Timers & oscillators
TTL technology
Bertus
before asking question I did google search for instruction execution
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Duane Benson
