I need help to solve this question
Discussion in 'Homework Help' started by ToinkToink, May 17, 2015.
  1. ToinkToink
    May 17, 2015
    I hope u guys can help me to solve question no ii and iii which is dc voltmeter loading effect. Thank you in advance ;);)
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    when you put the voltmeter across the resistor,its own internal resistance has an effect on the reading, the meter is acting as a resistor in parallel and lowers the Actual voltage, so you need to use a voltmeter with the highest internal resistance to get a more accurate reading.
    the actual Voltage across each resistor is 12V, so if you calculate the"effective " resistance with meter, then you use ohms law to give the volmeter readings.
    0Wafi0 likes this.
