I found these components in an old electronic parts box that once belonged to my wifes grandfather. I’ve tried to use Google searches with the markings on the parts, but I’ve been unsuccessful in identifying what these might be. I've attached an image of the parts in question.
Part #1
In this component some of the metals blades are stationary, and the other blades rotate through the stationary blades. The blades never seem to touch each other regardless of where the dial is turned.
Part #2
This component has 15 leads, numbered 1 through 15 as you can see.
The number show in the picture is 1346723.
There is another number on top of the component which is not shown in the picture, 675791-1
Part #3
This component has 8 leads, numbered 1 through 8 as you can see.
The other two numbers are 848 and 219V044H01.
Part #4
This component has no identifying marks at all. It has two leads, one for each side of the device. And both sides of the device have the same metal swirl pattern.
Thanks for any assistance given to help identify what these components might be.
Part #1
Part #2
Part #3
Part #4
