i need help solving current using nodal analysis.
Discussion in 'Homework Help' started by vant0210, Feb 9, 2010.
  1. vant0210
    Feb 9, 2010
    please guys, help me asap.
  2. The Electrician
    Oct 9, 2007
    2,300
    335
    You have to show some effort first before you'll get help.
  3. count_volta
    Feb 4, 2009
    435
    24
    Do KCL at nodes V2 and V4 and V5 then notice that V3=V5, and that you know V1 = 24V, so you need 3 sets of linear equations. Mess around with algebra, stick it in a 3X3 matrix and you're done. But we expect you to do the work yourself.
    Btw, Just did it myself by hand to prove to myself that I can still do these type of things. Current i should end up being 1.75A, which the circuit simulator confirms.
    I love the values professors in beginning courses give. 1.75A would cause your circuit to catch on fire in real life.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Perhaps it would be beneficial to take a look at the node voltage method applied to the solution of an example problem such as the one located here in the AAC ebook.
    hgmjr
