I need help regarding short time boosting current
Stevelee1982
Joined Jan 21, 2016
7
I am creating a circuit to boost the amp from 25A to 35A for few seconds
My supply is from a battery using 48V dc 25A
I need to learn how to short boost the amp to 35A
I did some research but still got no idea
Thanks a lot for the help
Dodgydave
Joined Jun 22, 2012
11,302
Thats converting AC to DC, like in a switchmode psu, you might get an increase in current but the voltage will drop, you can't get more out than you put in.
ErnieM
Joined Apr 24, 2011
8,377
What you need do is get some storage device that can hold 10 amps at a steady voltage for these few seconds, then be recharged.
The best device for this is another battery.
strantor
Joined Oct 3, 2010
6,798
How do you know that your battery can only supply 25A? Does your motor stall or what?
How do you know that 35A is the value that you need to achieve?
Stevelee1982
Joined Jan 21, 2016
7
It's just written on the battery and the controller will power cut if the battery supply does not supply enough for the initial start
So i am thinking of a way to let it have enough for the start so once the Motor Start moving it does not really cut off and the extra load is not needed
strantor
Joined Oct 3, 2010
6,798
It still isn't clear whether you've actually experienced the situation where your battery does not provide enough amps.
The reason I ask is that 48V * 25A = 1.6HP. This sounds like a traction system; maybe a small scooter or ebike, or even a high power RC car. In systems like that, the battery is often spec'd in terms of continuous discharge amps and peak discharge amps (sometimes expressed as a "C" rating). If your battery is rated for 25A continuous output, then it almost guaranteed to be capable of outputting much more than that (like 10X, 250A, or more or less) for brief periods (you wouldn't need to add or change anything at all). I suspect that is the case here, going on what limited info you've provided.
However, if your battery is rated 25A max discharge rate, then in all likelihood it is already undersized for the job. If your battery has 25A max output, and you're going to demand 1000+W from it continously, it's going to drain faster than a brand new toilet.
#12
Joined Nov 30, 2010
18,224
There is nothing in your link that says the motor will commit suicide if given its proper voltage. There is nothing written about limiting its initial current. Trying to give the motor more current is exactly the opposite of limiting it's starting current. The link says the fuses usually blow because of a start current of 20 to 30 times the running current. Giving the motor even more current only makes the fuse problem worse.
#12
Joined Nov 30, 2010
18,224
That certainly helps. It establishes that a DC motor can hurt itself if you apply the recommended running voltage when it is not moving because too much current is the result. Now we consider that the Original Poster, Stevelee wants to add even more current than the usual amount...or maybe he read the labels, doesn't know what they mean, and thinks a battery of 25 amp-hours capacity can not deliver more than 25 amps.
I think this is another case of a person asking for what they want instead of what they need. A belief in the absolute value of a label, entirely misinterpreted, leads the questioner to want the opposite of what he needs.
strantor
Joined Oct 3, 2010
6,798
That's what I suspect as well, and I was trying to chase the devil out of the dearth of details.
I have $5 that says OP's battery can supply more than ample current, and his controller is more than sufficient to limit starting current. He doesn't need anything at all and is the victim of nameplates.
