i need help plz
Discussion in 'General Electronics Chat' started by toookyo, Feb 8, 2010.
  1. toookyo
    Feb 8, 2010
    i want 2 know how to find out the value of diode ziner
    i kow that the resistor is known by the colors , but i need the glass-sealed zener diode and the black or gry colored
  2. mik3
    Feb 4, 2008
    4,846
    63
    You can find the purt number typed on its body.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Like mik3 said, reading the part number from the body is the best way to determine the specification.
    However, if the part number is unreadable, and the part is still good, you may be able to determine it's voltage by passing a known constant current through it in reverse bias.
    For example, a 20mA reverse bias current will give you the breakdown voltage of many Zeners. That would be too much for low-current Zeners.
  4. mik3
    Feb 4, 2008
    4,846
    63
    I am not Bertus. :p
  5. badbaud
    Member
    Mar 5, 2009
    26
  6. toookyo
    Feb 8, 2010
    thanx 2 u all
    (reading the part number from the body is the best way to determine the specification.
    i tried it by writing them on the net and i didnt get good info.
    i will try the other ways
    thanx very much
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    So what is the number?
