i need help on scientific calculator press
Discussion in 'Homework Help' started by hkra, Jul 8, 2005.
  1. hkra
    Jul 3, 2005
    18
    http://tinypic.com/6xrfgp.jpg
    see the picture
    how to calculate between 10-4
    my scientific calculator have no -4
    how to press can show me this formula?
    the answer is = 2.513 /_ 89.8º
    i just wanna know how to calculate the 10-4
  2. hkra
    Jul 3, 2005
    18
    fx-570W
  3. n9xv
    Jan 18, 2005
    329
    On most calculators there is a key labeled "EXP" that stands for EXPONENT. The key is usually programed to mean "X 10 to the EXPONENT of" and then you press the negative key " - " and then press the number " 4 " key. So, in your problem it would be;
    2.513 then press "EXP" then press " - " then press " 4 ".
    You can also do it this way;
    Anytime you see the base 10 to a negative exponent, you must have enough zero's + 1 to equal the exponent, like this;
    10^-4 means .0001
    a decimal followed by three zero's and ALWAYS ending with a one.
    10^-6 means - - - .000001 - - - decimal then five zero's and a one.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    The users manual for the calculator would be the best place to look for this information.
    hgmjr
  5. hkra
    Jul 3, 2005
    18
    great! i get the answer. thanks JoeJester ,n9xv and hgmjr
    sorry me forgot everything i have the last 2 subjects to resit before graduted
    but n9xv 10^ the ^ no such charracter on my scientific calculator
  6. hkra
    Jul 3, 2005
    18
    thank you very much. i understood
