i need help making circuit that sense the current change (di/dt)in overhead current
Discussion in 'The Projects Forum' started by ehab_salama91, Jan 18, 2011.
  1. ehab_salama91
    Jan 13, 2011
    hello guys i really need ur help in making circuit that can sense the current fault using the di/dt technique and then it indicate the fault by turning on led then i use timer to reset back the led off if the current returned back to its value plz help me guys
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is hard to understand. Do you mean to detect a lamp failure by monitoring current? Or is this to detect a short circuit?
  3. jaangalab
    Mar 28, 2010
    12
    pls define clear u want
  4. ehab_salama91
    Jan 13, 2011
    i need to design circuit that indicate if there is any failure in the current in the cable of the overhead transmission line that will light led when there is failure in the transmission line and i want do that by hardware
    thanks alot for replying me and i hope u can tell me about what i need
    thanks again
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the "overhead transmission line" carrying? Is it a signal or does it transmit high voltage power?
  6. ehab_salama91
    Jan 13, 2011
    yes its high voltage power from 12 kv to 24 kv
