I need help in designing a heatsink for my PCB
Discussion in 'The Projects Forum' started by pjreijiri, Apr 22, 2016.
  1. pjreijiri
    Aug 19, 2015
    60
    Hello everyone,
    I am designing a controller for 2 hub motors and I am using IRFP4468 MOSFETs.
    There are 8 MOSFETS in total but only 4 working at any time since I am using them as H-Bridges.
    I am new in the world of PCBs. I already finished the PCB design but I need to design a heatsink for it.
    I tried calculating the heat load, I got the following
    I=7.5 A through each H-bridge
    V=48 V
    q=123.6 W
    Osa=0.3 C/W
    Did I do the calculations correctly?
    Now I need to figure out if I need a heatsink and if yes, how big do I need it to be?
  2. Picbuster
    Member
    Dec 2, 2013
    391
    53
    pjreijiri likes this.
  3. SLK001
    Nov 29, 2011
    851
    243
    The RDS(on) for this device full on is only 2.6mΩ. The power dissipated by the device will be P=I^2⋅R. At 7.5A, P will be 0.146 watts. Your device is rated for over 250 AMPS drain current.
    IF this device is operated at either FULL-ON or FULL-OFF, then any basic heatsink can be used, since it will only dissipate 0.073 watts operating at 50% duty cycle. You might be able to even dispense with the heatsinks, depending on the duty cycle.
  4. shortbus
    Sep 30, 2009
    4,095
    1,682
