I need help identifying blown capacitor on power supply.
Discussion in 'General Electronics Chat' started by Pardoe, Feb 6, 2016.
  1. Pardoe
    Feb 6, 2016
    11
    Like the title says I have a blown power supply, a large capacitor failed and the fuse didn't catch it in time, I've been able to test and identify everything except this little guy.
    No markings on it, if there were markings they left with the smoke.
    This power supply is for a recording console so I assume this capacitor is filtering...
  2. bwilliams60
    Nov 18, 2012
    734
    94
    Do you have any information on the recording console? Make, model etc?
  3. Pardoe
    Feb 6, 2016
    11
    Audient ASP4816
    But they are very hush hush
  4. Sonoran Desert Tortoise
    Member
    Oct 30, 2014
    53
    34
    There is a crumb under C8, any chance you can find others and piece it together?
  5. SLK001
    Nov 29, 2011
    849
    242
    File the outer coating down to the ceramic and measure its thickness, then measure the diameter of the metalization. With these two numbers, you can find the approximate value of this capacitor.
  6. Pardoe
    Feb 6, 2016
    11
    Measure the thickness of red, blue or green?
    What 2 measurements am I looking for?
  7. SLK001
    Nov 29, 2011
    849
    242
    First, take the capacitor out of the circuit and measure its capacitance. It doesn't look shorted, just "punched through". It will not be the correct original value, but it will give you a ball park starting point.
    It is a single layer device. From the edge, it will look like:
    A metal layer, followed by a dielectric layer, followed by another metal layer. The thickness of the dielectric is found by filing the edge of the shell down to the dielectric layer.
    Once you have the dielectric thickness, scrape the outside layer of the shell down to the plated metalization layer and measure the diameter of that metalization. I would assume (a monsterously bold assumption) that it is an NPO type dielectric, since it appears to be a snubber on the primary of the transformer. Now you have the area, the separation and the dielectric constant, so you can calculate the capacitance.
  8. Pardoe
    Feb 6, 2016
    11
    I appreciate your help, I'll get to it right away and bring back my findings, one day, I want to be as knowledgeable as you. Real talk.
  9. Pardoe
    Feb 6, 2016
    11
    I was able to identify the cap as a 221k (220pF) 1kV.... New question is, with no clue about the +\- direction, how can I go about figuring that out?
    My clues are as follows
    One side connects via trace to a transformer.
    The other to a 100ohm 1v resistor, the resistor then traces to a dioed.
    Would it be a correct assumption that the + side connects to the transformer?
    Or does it matter at all on ceramic type caps?
  10. Pardoe
    Feb 6, 2016
    11
    Hey I wanted to get you a little info because the market for repairs on this console is more than likely about to ramp up and they won't be cheap.
    The PSU PCB is designed and built by a company called "PSU Designs LTD". The board itself is has a model code of PCBM-9260072-M1.
    I don't know if this helps but I would love to find a schematic one day.
  11. Hutkikz
    Jan 29, 2016
    9
    Nope doesn't matter, there are no polarity markings on ceramics
    Pardoe likes this.
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,686
    1,297
    This is a low cost, generic little ceramic cap, and not polarized. Just about dielectric will work in this application.
    ak
  13. Pardoe
    Feb 6, 2016
    11
    I ordered them offline, radio shack is useless.... Unless you want a cellphone, or a couple resistors
  14. Pardoe
    Feb 6, 2016
    11
    Ok so I'm not as cool as I thought I was, I did the entire repair that ended up being 2 resistors, 3 capacitors, and a fuse, but now the fuse blows every time I turn it on, what now.
  15. Pardoe
    Feb 6, 2016
    11
    One thing that is a bit different that might be causing the fuse to blow is...
    The original fuse was 3.15a 250Vac ceramic type, I'm testing my repair with a 3.15 250v glass type... Could this cause it to blow?
    I really hoped I could figure this out but I'm losing hope.
  16. john hauton
    Dec 19, 2009
    8
    I would check the main switching transistor(s), they sometimes go dead short. I cant see how the blown cap relates to this. It looks like its just a filter or snubber.
  17. Pardoe
    Feb 6, 2016
    11
    John,
    The small cap was only one of the issues. When I opened the power supply it had damage to a large cap this small cap and another 35v cap, 2 resistors were crisp. All that has been replaced. And yet it's still blowing fuses, I was afraid it might be a transistor. I don't really have the ability to load test transistors. :(
  18. RichardO
    May 4, 2013
    1,336
    429
    How was the original fuse marked. You may be trying to replace a slow blow blow fuse with a fast blow fuse. If you are, the fast blow fuse will blow........ faster.
    Pardoe likes this.
  19. Pardoe
    Feb 6, 2016
    11
    Yeah the old one was a slow blow, these are just standard fast now fuses.
