I need help for Verilog code of this instruction please
Discussion in 'Programmer's Corner' started by dem, Apr 18, 2010.
  1. dem
    Apr 18, 2010
    Jump and Link, Jump Register
    These instructions allow for the assembly programmer, or compiler, to use function calls. Since an instruction can only write to the register file during the writeback stage (stage 5), the jump and link instruction must insert the value of PC+4 onto the pipeline and it must then propagate down to stage 5 where it will finally be written. This will require an additional multiplexor. Remember, that the link address needs to be covered by data forwarding the same as any other instruction writing back to the register file
  2. retched
    Dec 5, 2009
    5,201
    313
    Is jump_addr what your looking for?
    I dont really understand what your asking.. Do you want the command or you want code to do something in particular?
    Care to shine a little light on the subject?
  3. kingdano
    Member
    Apr 14, 2010
    377
    19
    I also dont know what you are asking - is there a specific task you need an FPGA to run?
  4. dem
    Apr 18, 2010
    N.B: I attatched all project for better understand of the question thank you for your help
  5. dem
    Apr 18, 2010
    I try to repeat the duestion with file attactchment hope you will understand this time thank you for your help
  6. dem
    Apr 18, 2010
    I attatched the file for all project maybe you get better understand for my question thank you for ur help
  7. retched
    Dec 5, 2009
    5,201
    313
    I stil have NO clue what you want. Do you want me to do your homework?
    Show what you have so far so we can see where you are stuck.
  8. kingdano
    Member
    Apr 14, 2010
    377
    19
    this - i dont understand what you are asking.
    i can say that there is not a verilog command that will do that in one shot for you.
