i need help for our project .
Discussion in 'The Projects Forum' started by melborn1010, Aug 28, 2014.
  1. melborn1010
    Aug 28, 2014
    7
    What value of the R1 to change the off delay to 3secs only?
    ThankYou :)
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The schematic notes say R1 of 1M = 20 seconds.
    So to convert 20 secs to 3 secs you need approx;
    1M /20 *3 = 150k (150000 ohms).
    If you want better than that, you can replace R1 with a 50k resistor in series with a 500k pot. That will give an adjustable time delay from approx 1 sec to 11 seconds.
    Bernard likes this.
  3. Bernard
    Aug 7, 2008
    4,233
    414
    In a one-shot C starts charging from gnd. so time is close to R X C so for 3 sec, R might be close to 300k.
  4. melborn1010
    Aug 28, 2014
    7
    sir , can i replace C547B transistor to any NPN or 2n2222 transistor? and if i put a 2pcs 12v relay any thing that can affect the off delay?
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    bc547 / 2n2222 are general purpose npn transistors, only thing you'd need to worry about there is pin configuration and data sheets are available providing google's not broke where you reside.
    and why 2 relays? get one with higher rating or more contacts.
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    If the C547B transistor is the BC547B the you can use 2n2222 to replace it.
    Why you want to use two 12V relays? (one 2N2222 for two 12V relays seems ok, but you still need to care the temperature)
    If you need more contacts then you can choose two sets of contacts, you got 6 pins to use.
  7. melborn1010
    Aug 28, 2014
    7
    the question is ..... C547B and BC547B same?
    yes ! i can use 6pins relay anyway :D
