I need help for my LED light
Discussion in 'The Projects Forum' started by leche, Aug 21, 2013.
Thread Status:
Not open for further replies.
  1. leche
    Apr 1, 2011
    14
    Hi everybody,
    I made led circuit to use it as dome light in my car.It works goo but there is a little problem.When i closed the doors it should turn off completely.But it isn't.It keeps to light a little bit.I mean it lights too poor but never turns off completely.The LEDs are 16x5050 SMD leds.So what can i wire to make it turn off completely when i close the doors?Thanks.
    This is the scheme of the circuit.
  2. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    Did you measure at the 12v?
    I suspect it is solid state switched.
    Max.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    Try a 220 ohm, 2 watt resistor in parallel with the load.
    (just guessing).
  4. wayneh
    Sep 9, 2010
    12,377
    3,231
    Uh oh. We know what that means. Thread closure coming in 3, 2, 1 ....
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
