I need help about Buck Converter!
Discussion in 'The Projects Forum' started by hasnain_raza, Oct 2, 2011.
  1. hasnain_raza
    Sep 21, 2011
    7
    Hello Bros!
    I m working on Solar panel project.I basically want to convert 40v dc to 24v dc because my solar panel out put is 40v.when i use simple buck converter then my mosfet get a high temperature and it burns!!!
    Then i searched on internet that a drive circuit is required for p channel or n channel mosfet to start its work! but i m facing problems.....
    which circuit you will prefer to drive mosfet ????
    Please help me!!
    Thanks in advance!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Post an image of your circuit as it is now. .PNG format images are preferred.
    Right now, we have no idea on how much current your panel might produce, or what you are trying to power with it.
  3. hasnain_raza
    Sep 21, 2011
    7
    i have posted pic now please chk it again!
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You have posted a portion of a circuit for an IR2110 half-H bridge driver, or a similar product.
    You have not mentioned how much current your panel can output.
    You have not mentioned what your load is.
    Are you trying to charge batteries?
    Are you powering some other load, maybe a DC to AC power inverter?
    What is the current requirement of your load?
    It will be very difficult to make any progress until these questions are answered.
